Hi Guzzi Guys,
750 engine Info.
Does anybody have the dimension.. Centre of Crank to bottom of the sump pan.
Weight of Engine ?
Do the have removable sump pan ?
Guzzi Engine Infomation.
stevep
- CSC Membership Number: 104
- Region: southg
Re: Guzzi Engine Infomation.
750 Breva dimensions
Crank centre to bottom of sump 170 mm approx
Sump pan drops straight down away from main engine ,oil capacity 1.8 L
You can get a oil sump extension that nearly doubles the oil capacity which is good for our use, the long distance racers
Use them
That adds 50mm under the engine not really a problem with a car.
Total bike weight 182 kg , no separate engine weight in the service manual.
Keep on revving
Use them
Keep on revving
Steve, thanks for the info.
Looking at replacement engine options, for a 4x4 2cv.
Extra drop at the sump, not good for a 4x4.
Has anybody maybe the racers done a dry sump setup?
