Just wondered who if anybody was running on E10 ???? With additives ??? without ?? Problems ??
I'm running E5 at the moment.
Dave
PS did I say ....my earlier problem was the idle jet ... it had dropped out !!
Fuel
ReinaldoAdamo
- Country: usa
- Region: New York
Re: Fuel
I haven't run E10 with supplements, but I can share my experience with E5. I think using E10 with or without supplements will depend on what supplements you want to use. Some additives may be compatible with E10, but others may cause problems. One of the main issues with using E10 is its effect on the engine. If your car is not specifically designed to use biofuels, using E10 can cause some problems. For example, the higher ethanol content can cause fuel system corrosion or ignition problems. If you want to use biofuels, it's best to find out about their compatibility with your vehicle and fuel system. You can also check with the manufacturer of your car or your dealer to find out what fuel is recommended for your model. As for the idle speed nozzle, I recommend that you check it and replace it if necessary. This can help improve the performance of your car and avoid problems in the future.
DaveWard
- CSC Membership Number: 2223
- Region: East Mids
Re: Fuel
Hi , many thanks, I'll stick with E5 .... its working ok ... so don't change
Re the idle jet , I got a replacement from Ecas,.... Its great , I think the old one must have been loose for some time before it fell out because the difference in performance and idling with the new one is tremendous .
