Oil Filter Sandwich Plates
DaveWard
CSC Membership Number: 2223
Region: East Mids
Post by DaveWard » Thu Apr 10, 2025 10:23 am
Hi Guys , had to put the project on hold for a bit
Have ordered plates but can't find one with the correct size brass bush , I just noticed one on-line with 3/4-16UNF bush but I'm assuming that's not the right thread . Any thoughts where I should be looking for one ??
Dave
Re: Oil Filter Sandwich Plates
Post by notsmartcar » Thu Apr 10, 2025 5:41 pm
I could dig a 2nd hand one out £20 including postage. You’re looking for a m16 bush as you call it so it takes the same oil filter.
CSC Membership Number: 2205
Country: United Kingdom
Region: Cumbria
Post by Davidm » Thu Apr 10, 2025 7:38 pm
Dave
Buying an M16 adapter would be ideal.
I struggled to find the correct threaded adapter so I made one but you need a lathe to do this.
If you use M16 threaded rod and drill the oilway through this avoids cutting the thread.
Post by notsmartcar » Thu Apr 10, 2025 8:16 pm
Demon tweeks sell them their made by mocal ask for M16;Center fitting.
Post by notsmartcar » Thu Apr 10, 2025 9:53 pm
I’ve just sold my mocal sandwich plate with its m16 connector. They realdily available just ring demon tweeks it’s only a hydraulic pipe fitting so you could even go to any hydraulic pipe supplier
DaveWard
Region: East Mids
Post by DaveWard » Fri Apr 11, 2025 2:30 pm
Many thanks Guys much appreciated
DaveWard
Region: East Mids
Post by DaveWard » Thu May 08, 2025 3:48 pm
Hi GUYS just to say a big thank you . I re-ordered the sandwich plate and ordered an adaptor of the correct size ( 16mm ) from Demon Tweaks .
All fitted and works a treat . Many thanks for your advice and chat.
Dave
