Oil Filter Sandwich Plates
DaveWard
- CSC Membership Number: 2223
- Region: East Mids
Hi Guys , had to put the project on hold for a bit
Have ordered plates but can't find one with the correct size brass bush , I just noticed one on-line with 3/4-16UNF bush but I'm assuming that's not the right thread . Any thoughts where I should be looking for one ??
Dave
Dave
Re: Oil Filter Sandwich Plates
I could dig a 2nd hand one out £20 including postage. You’re looking for a m16 bush as you call it so it takes the same oil filter.
- CSC Membership Number: 2205
- Region: Cumbria
Dave
Buying an M16 adapter would be ideal.
I struggled to find the correct threaded adapter so I made one but you need a lathe to do this.
If you use M16 threaded rod and drill the oilway through this avoids cutting the thread.
Demon tweeks sell them their made by mocal ask for M16;Center fitting.
I’ve just sold my mocal sandwich plate with its m16 connector. They realdily available just ring demon tweeks it’s only a hydraulic pipe fitting so you could even go to any hydraulic pipe supplier
DaveWard
- Region: East Mids
Many thanks Guys much appreciated
DaveWard
- Region: East Mids
Hi GUYS just to say a big thank you . I re-ordered the sandwich plate and ordered an adaptor of the correct size ( 16mm ) from Demon Tweaks .
All fitted and works a treat . Many thanks for your advice and chat.
Dave
Dave
