Lomax ignition coil position.
hotfoothowell
CSC Membership Number: 1966
Region: Warwickshire
Post by hotfoothowell » Sun Oct 20, 2013 3:08 pm
My Lomax ignition coil is mounted on the engine between the starter motor and the gear change linkage. For some unknown reason, the handbrake linkage assemby has started to foul the left hand ignition lead, when the handbrake is applied, pulling the lead off the coil terminal. The only solution seems to be to move the coil- can anyone suggest a good position, where it will neither be drenched nor roasted? Thanks, Patrick
Re: Lomax ignition coil position.
Post by hutchii » Tue Oct 22, 2013 8:43 am
Patrick,
If you're satisfied that the coil is not getting "drenched or roasted" where it is, can you not simply change the HT leads? Shorter ones, with maybe a right angle attachment at the coil end so that they are directed towards the front of the car, away from the handbrake linkage. Leads are available singly in a variety of lengths and ends from most motor factors. Halfords also sold them, last time I looked.
My ECAS Supercoil is mounted on a bracket which spans the two large (10mm) studs at the top of the gearbox. When I realized that the HT leads were "rubbing" on the underside of the bonnet, I simply reversed the leads and by doing so was able re-route them to ensure that they no longer fouled anything!
hotfoothowell
Post by hotfoothowell » Thu Oct 24, 2013 9:36 am
Thanks for the suggestion. Halfords no longer sell ignition leads. The main problem seems to be finding a right angle connection which will fit the Citroen HT coil output.
Mike
CSC Membership Number: 1663
Region: South west
Post by Mike » Thu Oct 24, 2013 12:12 pm
hotfoothowell wrote:Thanks for the suggestion. Halfords no longer sell ignition leads. The main problem seems to be finding a right angle connection which will fit the Citroen HT coil output.
Try "Vehicle Wiring Products" they sell a whole range of HT leads and fittings :)
hotfoothowell
Post by hotfoothowell » Thu Oct 24, 2013 6:55 pm
Thanks, but have already tried them.
Post by hutchii » Fri Oct 25, 2013 10:11 am
Patrick,
If you speak to Ecas, I think you'll find that the leads they supply with their "Super coils" are supplied to them without one of the ends fitted. Not sure whether it's the straight or right angle end but, either way, if you tell them the length you require, they could provide what you want. (Assuming they're shorter than normally supplied)
Le Patron
Country: NL
Region: middle
Post by Le Patron » Tue Dec 03, 2013 9:14 am
When problem finding, I can make straight or angled connection on 7mm or 8mm ignition leads, every length.
Kind regards,
Godfried van den Bergh.
bassmaster
CSC Membership Number: 2313
Region: South East
Post by bassmaster » Wed Dec 10, 2025 11:46 am
Hi.
I live on the Isle of Wight and have just joined the club.
I recently purchased a part built Lomax 223, and am going to need some information from all you guys out there please?
re: the Ignition coil on the Lomax, I can't see how it's possible to attach it to the engine between the starter motor and the gear lever?
or should that be attach it to the gearbox?
Does anybody reading this know if we have a member with a Lomax, living on the Isle of Wight please?
