Wire Wheels
CSC Membership Number: 2163
Region: Essex
Re: Wire Wheels
Post by Rocketman1955 » Sun Jun 14, 2020 2:49 pm
Regarding tightening & self tightening of wire wheel spinners: I have just fitted a new pair of MWS 48 spoke wheels to my 223.
Having previously seen this discussion & decided to experiment & take some measurements .
From thread engagement to hand tight with the wheels seated on the hubs & the car jacked up, the spinners turned about 2 1/2 turns.
(no way will they go 3 1/2)
Then for the subjective bit, I used a 3lb club hammer onto a piece of 2x2 timber to protect the spinner ears.
I do not like over tightening hardware & the previous responses suggest the system should be fail-safe.
4 moderate hits jacked up and 4 on the ground.
This gave an extra 100deg on the left spinner and 50deg on the right spinner.
The spinners & wheels were then marked.
After the first outing today of about 40 miles I checked the marks.
Left side - still aligned
Right side - 2mm (2.5deg approx) UNDONE
Spinners are on the correct sides of the car.
Maybe right spinner was not as tight (50deg vs 100deg on left side) but the previous discussions suggest that should not matter................
I have retightened the right side 2.5deg tighter than previously & will see what happens!
Region: Essex
Re: Wire Wheels
Post by Rocketman1955 » Thu Aug 06, 2020 8:36 pm
Update on self tightening spinners - or not.
Following on from the previous item, the car has now done about 300miles general driving, mainly with a passenger on board.
Both spinners have tightened up by about 1.5mm at the spinner rim. (right side from the re-tightened position).
craptiger
Region: Somerset
Re: Austin 7 Wire Wheels
Post by craptiger » Mon Nov 02, 2026 7:32 am
I'm looking to fit 18 inch wire wheels to my Lomax and someone suggested Austin 7 wheels might be a good way to go, but I'd need a special 3 hole adaptor plate. Has anyone had any of these made, or know where I can get some? MWS don't offer these.
Re: Wire Wheels
Post by hutchii » Wed Nov 11, 2026 8:28 pm
Hi.
I think almost any half decent machine shop could make a suitable wheel adaptor. The ones that MWS sell for the MGA 48 spoke wires are pretty simple. An expensive way to get what you want would be to buy those and get them modified by turning of the spliced spigot to create the correct size register for your chosen wheel, and drill and tap the required number of holes at the desired pitch circle diameter.
Or maybe buy one and take to a machinist as a sort of pattern?
Good luck.
