Floor mounted gear change
Armando
Region: Herefordshire
Re: Floor mounted gear change
Post by Armando » Tue Jun 02, 2015 4:33 pm
hutchii wrote:Peter,
If you haven't purchased the rose joints as suggested by Geoff yet, I see from the linked site, that the company sell a matched pair, i.e. male and female rose joints that you can screw together, and therefore not need the piece of studding. True this solution won't give you as much adjustment but, fully screwed together they'll give you, I guess 30mm more clearance, and you can extend from there by probably another 15mm. The material used for these joints will also be much stronger than almost any studding you might use. (unless of course you chop a lump of thread from a decent set bolt!)
Just a thought.
Geoff and Peter: I'll jump in here and say thanks! That's one modification I'll do - looks more substantial than the original Citroen part.
A.
motomallett
CSC Membership Number: 2031j
Post by motomallett » Tue Jun 02, 2015 6:35 pm
Hi this is the adjustable gear linkage on my PAC its pretty substantial. sorry cant seem to get pics any bigger
regards Roger
gear change 003a.jpg (21.75 KiB) Viewed 3992 times
gear change 002a.jpg (20.9 KiB) Viewed 3992 times
gear change 001a.jpg (21.63 KiB) Viewed 3992 times
