2CV rear hub removal
Re: 2CV rear hub removal
Post by Jack602 » Thu Jul 15, 2021 3:17 pm
Tony,
I used the ECAS brake adjuster kit on my Pembleton.
The head on the bolt supplied with my kit fouled the brake shoes (I used a smaller head bolt from my stock), the ECAS site talks about a modified kit and the screw head appears smaller, so you should be fine - but worth checking.
Pembleton SuperSport (passed its first MoT this week!).
Tamos
Region: Kent
Post by Tamos » Thu Jul 15, 2021 4:10 pm
Thanks Jack, will speak to ECAS.
Tony
Post by QFAD » Fri Jul 16, 2021 2:17 pm
:o :shock: :lol:
CSC Membership Number: 2163
Region: Essex
Post by Rocketman1955 » Sat Jul 17, 2021 6:32 pm
Ref the hub nut torque - I have just taken my drum off.
The active arm was on RHS and when trying to undothe nut the suspension arm went up into the body before I could get enough torque on to undo the nut.
I had seen the 2 CV trick of putting a wedge above the arm to effectively lock it to the body and react the torque, but could not see any easy way to do that on my Lomax without risking pushing the boot floor out!
Eventually I borrowed a chordless impact wrench that took it off in seconds.
I agree with the above comment about not overdoing the torque when doing the nut up.
I have a 30ins long torque wrench and was surprised how little force is required to get the correct torque.
Makes me wonder why owners have such problems undoing them - I suspect mechanics have just done them up 'tight' rather than using the specification? Of course the locking nut also has to be clear of the threads!
Post by notsmartcar » Sun Jul 18, 2021 2:10 pm
If I get a really stubborn one I have a scaffold pole and put it over or under the axle behind the back plate to suit the torque reaction and also the only time I’ve lost threads on the stub axle is when I’ve tried to drill out the peening on the nut ..so I never do that any more
CSC Membership Number: 2205
Country: United Kingdom
Region: Cumbria
Post by Davidm » Sun Jul 18, 2021 7:51 pm
To restrain the suspension arm when loosening or tightening the hub nut I made a tool with a piece of heavy section channel (about 2 ft long) drilled near the end to fit a wheel stud and a steel strap (about 10" long) between a different wheel stud and that channel.
I tried to attach a photo but the file is too big ?! - Is there a way to overcome this ?
The tool works well - I wish it had been my idea.
Post by Jack602 » Sun Jul 18, 2021 9:22 pm
David,
To resize a photo:-
Open photo, right click on photo, you will have an option to Resize, I choose "suitable for email", then Save (I add Small to the title) & then post this new copy.
Hope this helps
Region: Cumbria
Post by Davidm » Mon Jul 19, 2021 11:43 am
2cv hub restraint tool
2cv hub tool.JPG (384.73 KiB) Viewed 10078 times
Region: Cumbria
Post by Davidm » Tue Jul 20, 2021 1:08 pm
Apologies but I've posted a red herring ! That tool I suggest for restraining the hub works for the front hubs but not the rear hub because the hub nut for the rear hub clamps the bearing inner races to the swinging arm - not the hub and brake drum.
So to undo the hub nut to remove the rear hub the swinging arm needs to be restrained eg by using a scoffold pole as notsmartcar above or in my case I confess to using stilsons to grip the suspension arm just behind the brake backplate.
