Oil cooler hoses - I've sprung a leak!
Highwaylass
- CSC Membership Number: 2024
- Region: West Midlands
Re: Oil cooler hoses - I've sprung a leak!
Pirtek Cambridge did them for me - good blokes!
Dave Guest
- Region: Herts
Thanks for the info. I'll give them a ring
Highwaylass
Ask for Kevin
Dave Guest
- Region: Herts
Many thanks. Just a quick one... I see how the hoses fit the engine but is there some sort of fitting to fit on the spigot on the oil rad also which branch is Kevin at. I greatly appreciate all the help as I've already waisted time and money on the wrong hoses.
Cheers Dave
Cheers Dave
Is it the standard 2CV oil cooler or a Mocal unit? I've used plumbing compression fittings on the Citroen cooler after cutting off the original fittings.
Dave Guest
- Region: Herts
I must learn to read previous posts before posting my own..Cambridge.
I have the standard 2cv cooler with cut off pipe so 10mm plumbing compression fitting does sound like the way to go.
Thanks for the help
Thanks for the help
Or you can use pneumatic compression fittings they obtainable straight or elbow compression to compression or compression to hose tail or banjo, pretty much anything. just Google Enots they are sold by many air and hydraulic equipment suppliers.
The pictures show 10mm OD elbows connecting chopped off aluminium cooler pipes to 10mm copper central heating pipe.
- Snapshot 1 (28-04-2014 11-26).jpg (94 KiB) Viewed 11179 times
- Snapshot 1 (28-04-2014 11-27).jpg (87.35 KiB) Viewed 11179 times
Yes - pneumatic fittings would have a much greater range of adapters and they can be had in brass, nickel or stainless.
