Brake master cylinder
Marcf
Region: Sussex
Post by Marcf » Sat Oct 22, 2016 10:41 pm
Evening,
I've just taken on a part built 223 and after some advice on fitting the master cylinder.
Can anyone help with a diagram or explanation of how the pedal box and master cyclinder should be fitted please??
Many thanks
Marc
tibetans
CSC Membership Number: 1210
Region: North West
Re: Brake master cylinder
Post by tibetans » Sun Oct 23, 2016 9:29 am
Not sure if you have a copy of the build manual for Lomax - see link below.
http://www.sportsandleisurecars.co.uk/l ... al_pdf.pdf
Richard
bassmaster
CSC Membership Number: 2313
Region: South East
Post by bassmaster » Wed Dec 10, 2025 12:19 pm
This exactly my situation.
Just taken on a part built Lomax 223.
I have the build manual, which is not the most helpful instruction manual I have ever seen
I am not sure exactly where to position the pedal box, but also I don't have the adapter brackets that are mentioned in the manual
Can anyone help please?
Many thanks
Post by cmwbob » Wed Dec 10, 2025 2:25 pm
Drg of Pedal box brkt
Regards Rob
pedal box 2cv.pdf
(5.06 KiB) Downloaded 5421 times
bassmaster
Region: South East
Post by bassmaster » Thu Dec 11, 2025 5:22 pm
Thank you very much Rob. That's very kind of you.I'll get one made up asap.
Just two questions please
1) what is the 16mm o/d tube for?
2) Does this bracket allow enough room in the engine compartment, to enable the original fluid reservoir to still be used?
Many thanks
Doug
