Poor starting
SimonHBanks
CSC Membership Number: 668
Region: East Anglia
Poor starting
Post by SimonHBanks » Sun Jul 28, 2013 1:40 pm
After a long period of inactivity I decided to take out my Lomax 223. Unfortunately I had a few problems and had to resort to the crank to get it started. I did about 10 miles and had the same problem after parking up for 10 min then again after only 5 mins of running. Each time I press the starter all I get is a slight dimming of the ignition light then if I am lucky the starter motor will kick in. It felt like a poor earth but so far I have been unable to find one. It was the hottest day of the year and the engine was very hot. The battery was reading about 11V. Any suggestions as to where to start looking would be good as my wrists now ache.
Simon
668
Re: Poor starting
Post by Ken Hanna » Sun Jul 28, 2013 3:51 pm
Simon,
sounds like your battery needs replacing.
Note the relationship between % of charge and voltage.
http://www.energymatters.com.au/renewab ... charge.php
Btw, what's the voltage when it is running?
Too much voltage is just as bad as not enough, 14.4 volts should be the upper limit.
SimonHBanks wrote:Hi,
Simon
668
SimonHBanks
Region: East Anglia
Re: Poor starting
Post by SimonHBanks » Mon Aug 12, 2013 11:13 pm
It was the Battery. All OK now.
